chugs at low speeds while driving
Old Oct 19, 2000 | 10:31 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
hope somone can help, I have an 89 L98 engine only mods have been a set of vette alluminum 58cc heads, a slightly larger cam, .500 lift and 114 degrees seperation, bottom end is totally stock, at low rpms 100-1500 it chugs and jumps, anything over 1500-2000 runs fine, and this only does it while driving, sits and idles just fine. any ideas? also I put a pete jackson gear drive in and the idler gear seems really loose, I lost the papers to see if the tolerances were right so if anyone has put one of these on I would apreciate a little help as well.
thanks
Jack
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flow's 2 1/2" exhaust true dualls
Old Oct 19, 2000 | 11:09 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
This may sound weird, but pull off your wires that are near the headers. You may have toasted one and not notice from a cursory inspection. The most likely one if it is this? The back pass. side wire, right at the boot/wire abuttment.
gta90
Sep 15, 2015 04:00 PM
perZ
Aug 15, 2015 01:17 PM
kyleb24
Aug 15, 2015 08:24 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
