PCV junk....
Old Oct 20, 2000 | 09:34 PM
z28cam100's Avatar
Car: 89 Trans Am GTA
PCV junk....
Can i remove the PCV junk without making my computer throw codes? I'm swapping engines and all the solid plastic lines that run to the valve onn the intake are broken and cracked and i don't where to get new ones. So anyway i want to just ditch the whole works and i want to know if it would work.
86 Camaro
305, T-tops, flowmaster exhaust, B&M shift kit
"Real cars are built, not bought"-some smart guy
http://hometown.aol.com/z28cam100/index.html
Old Oct 20, 2000 | 10:08 PM
Vader's Avatar
Z,
You can eliminate the entire PCV system if you want. The ECM won't care until the distributor stops turning from engine seizure caused by the lack of lubrication.
The PCV helps keep fuel contaminants, acids, and water vapor from collecting in the oil sump. Not venting the crankcase will cause the oil to turn into a oil/water/acid emulsification. This Jello will not lubricate well, and will eventually lead to engine destruction.
Of course, you could just change oil and filter every week (you'd have to change the filter because the larger water molecules will saturate the filter paper and cause the filter to go into full bypass). And you'd still get moisture and acid formation, but draining it every week should eliminate the really high levels that cause serious damage.
Then again, you could just replace the hard plastic tubing that has failed, or use rubber fuel/vapor hose instead of the plastic. That would probably be the easiest and best solution.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 21, 2000 | 08:02 AM
z28cam100's Avatar
hmmmm...kill new engine..or use PCV stuff...
uhhhhh
well then i guess all my PCV stuff isn't going anywhere then
thanks for the help
86 Camaro
Pac J
May 17, 2020 10:44 AM
tyeo098
Nov 30, 2015 06:27 PM
NZKnight
Oct 15, 2015 02:47 PM
sleprock
Sep 24, 2015 04:33 PM
CatmanFS
Sep 19, 2015 09:00 AM
