Boy am I stupid.....
Old Jul 29, 2003 | 02:45 PM
92RS3.1L's Avatar
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
So I just changed my oil pan cause it rusted like a mother. I installed the new gaskets, and with the gasket came that little plastic O-ring. I put that one on, and I didnt even see the one that was already attatched to the oil pan, but was painted over The oil pan is leaking again, and I think thats the problem. Is it possible to take the oil pan valve cap off, and put my finger over the hole so oil doesnt rush out like crazy, and take that extra O-ring off? or do I have to drain the oil ALL over again, and take the O-ring off, and put whole new oil in ALL over again?
Old Jul 29, 2003 | 04:45 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
if its leaking that bad you might as well just drain and refill it with new oil..
Old Jul 29, 2003 | 05:57 PM
ede's Avatar
ede
2 seals wouldn't hurt, as long as they were both good to start with. catch the oil and put it back in. are you sure you got the gasket on right?
Old Jul 29, 2003 | 08:50 PM
92RS3.1L's Avatar
Car: 91 Z28
Ok, me and my dad put the car on jackstands and took a look under the car. The good news is that there is no oil leaking around the bolts that hold on the oil pan, but the bad news is that I still dont know where it is leaking from, and on top of that I am also leaking transmission fluid. Oye Vay.
Old Jul 29, 2003 | 09:28 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Sounds like it is time for a 406 and a t-56
Old Jul 29, 2003 | 09:34 PM
92RS3.1L's Avatar
Car: 91 Z28
haha, yea. get an engine with a little more danglers than my V6.
Old Jul 30, 2003 | 06:18 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Is the new pan slightly bent somewhere and not sealling properly?
Old Jul 30, 2003 | 12:12 PM
92RS3.1L's Avatar
Car: 91 Z28
Ok, I was wrong. It isnt oil thats leaking, its trans fluid. I will get that fixed immediately. Thanks guys for all your help.
Elephantismo
Feb 13, 2019 12:51 AM
85cmroz28
Oct 4, 2015 09:44 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
