something strange happend,y..
Old Jul 29, 2003 | 05:56 PM
icebird_1981's Avatar
k well today i was just driveing normal and i turn down a side street to see this girl, when makeing the turn the car stalls out. ok that was a first, so i start it back up and continue, reach the end of the street and she stalls out again. but this time she would not start up, i mean it would start for a split sec then die. so i think crap i am out of gas and somethings up with the gauge. so i go get some gas put it in and it gives me a hard time but stays on after reving a bit. so i think everything is fine just a bad gauge. and go on the main street again. driveing normal go to brake car stalls again. so i pull in a driveway and think maby my fuel pump, i take off a line and start it>gas shoots out>so that good.
then i turn up the idle on the carb. give it a shot car starts, soon i put it in drive she stalls. so i start checking all the lines again and the fuel filter, along with pushing all the plugs down to make sure they are all on. i go and start her, and everything is fine. got no more problems after that. what the heck was going on? should i look into this? or just leave it hopeing its just a one time thing?
Old Jul 29, 2003 | 06:10 PM
ede's Avatar
ede
it'd help if you said what you had, but since you didn't i'll guess. tc lock up switch bad.
Old Jul 29, 2003 | 06:12 PM
my bad sry, 350,holley 750VS, th350 trans.>with all the mods along with it.
what is a TC lock up switch? were is it?
Old Jul 29, 2003 | 06:47 PM
well i just called my mechanic and hes saying it prob the ignition?<(sp) modual, because sometimes they heat up and dont wanna go. could this also be the problem? i'm affraid to drive my car now!
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
RedLeader289
Sep 23, 2015 06:50 AM
BWilcox
Sep 20, 2015 12:19 PM
///DAN///
Brakes
Sep 17, 2015 07:43 PM
