Injectors for a 383
Old Oct 21, 2000 | 07:09 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Injectors for a 383
I'm building a 383 for my IROC and for some reason I started thinking about injectors. I have 22# flowmatched injectors right now. Will those flow enough fuel for a 400 hp 383 with a SuperRam? I am making a custom chip for this setup if that matters.
Mark Lock
- 86 IROC-Z - My car, mods and ET's
- -= IROC Online =- - The site dedicated to the IROC-Z
Old Oct 21, 2000 | 07:37 PM
Lounge Lizard 6's Avatar
The 22's can fuel a 383 but you might get above the ideal 80% duty cycle with them. I'm running GM 24's on my ZZ4 so I think you should/could run 30's.
Mike
'90 IROC-Z, 5-speed, ZZ4, Trick Flows
Moderator SEThirdgen
Old Oct 22, 2000 | 01:54 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
as far as i've found 22lb injectors will run a mild 383, but they don't leave much room for modifications to them. 24 is enough for a strong 383. i'm going with 30 to leave room for possible supercharger later, but also just so i know i'll have enough and don't need a ton of fuel pressure to keep up.
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
Keiffer76
Sep 9, 2015 08:52 PM
