Rear end swap question
Old Oct 21, 2000 | 11:32 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Alright the camaro is going to be stored next month and thats when im going to do all my mods on it, one of the first will be the rear end. OK, for the fourth gen swap, i read the tech article and i see it sticks out 2" each side wider. Is there any way to counteract this by even a inch or so? And to those who have done it does it look good or does it look out of place and ghetto looking? Or should I look for an old IROC rear end, if mem servs they had disc brakes and stock posi with some good gearing.
Any comments?
Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat,
Old Oct 22, 2000 | 08:43 AM
ede's Avatar
ede
i think with the 4th gen rear if you use 4th gen wheels they fit and look the same, don't stick out too far.
-=ICON MOTORSPORTS=-
Old Oct 22, 2000 | 02:35 PM
Biochem's Avatar
Car: 2002 SOM z28
A 4th gen rear will use 4th gen rims due to their off-set being less then the 3rd gen rims.
You would need spacers if you were going to put 4th gen rims onto your stock 3rdgen rear...
Swapping a rear is somewhat easy. Took me about 4 hours to do.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
