Does a coil wear out?
Old Jul 31, 2003 | 08:10 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Does a coil wear out, or is it either good or bad?
Old Jul 31, 2003 | 08:26 AM
Vader's Avatar
Theoretically, no. Practically, yes. The coil windings themselves don't "wear out", per se, but the insulation around the windings can degrade, affecting the coil performance. Silicone oil filled coils seem to last the longest. Epoxy filled coils can last a long time, but tend to heat more quickly, and the heat is what accelerates the breakdown of insulation.
Having said that, it would seem a bit ironic that the oldest coil I have is an epoxy filled coil in a Fairbanks FMJ magneto, mounted to a 1938 Allis Chalmers B tractor. It's original. I'm still waiting for that coil to fail, and if it's within my lifetime I'll let you know.
However, larger coils (transformers) that are oil filled can last much longer with less insulation breakdown. Many large transformers have sample valves to tap off an oil sample for analysis, and properly cooled and maintained wet transformers will far outlast dry types. The same philosophies apply to a smaller transformer (coil).
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
