Leaking 3 different fluids!
Old Jul 31, 2003 | 04:45 PM
92RS3.1L's Avatar
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
Ok, so i put on my new oil pan, made sure the gaskets fit right and everything. Then today, i notice 3 different puddles under my car! One is OIL, the other is TRANS FLUID, and the last is ANITFREEZE!! What is going on? I checked the oil pan bolts, and they were all dry and oil free. What is goin on here? Where do I start looking?
Old Jul 31, 2003 | 05:20 PM
92RS3.1L's Avatar
Car: 91 Z28
Anyone?
Old Aug 1, 2003 | 07:58 AM
Vader's Avatar
Clean the engine thoroughly. Start it and allow it to reach operating temperature. Inspect for leaks. Anything leaking should be apparent. There are no places in, on, or around the engine that one leak would produce oil, transmission oil, and antifreeze puddles.
If you had a newer car with an engine oil cooler in the radiator, I'd guess you may have a catastrophic failure of the radiator but that would by in front of the engine, not under it.
FormulasOnly
Jul 23, 2018 08:47 AM
Mark_ZZ3
May 24, 2018 01:02 PM
jrdturbo
Mar 31, 2016 02:58 PM
HikoriYami
Sep 21, 2015 07:11 PM
Stryker412
Sep 20, 2015 06:59 PM
