How do I replace the water pump?
Old Jul 31, 2003 | 07:07 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
I haven't quite pegged the problem just yet, but judging from the coolant on my garage floor, I'm guessing it's more than a cracked hose. How long am I looking at, and what's the degree of difficulty? I don't have the time I used to spend finding and fixing things. Sometimes it seems easier to have someone else do it...not quite as fun though.
Old Jul 31, 2003 | 07:58 PM
86FirebirdV8350's Avatar
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
im 18 and never did one in my life, i tackled it and had it all done in about an hour. You just need to get stuff out of the way (just take the alternator out and move the power steering pump over and hang it from something, and you'll be fine, theres about 6-7 bolts that hold it to the engine, just take those out and use a block of wood and a hammer to hit the pump so it comes off(probably stuck on there good like mine was) just makes sure u put the new gaskets on and seal those nice and everything will go good
Old Jul 31, 2003 | 09:10 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Try to loosen the 4 bolts on the water pump pulley before you pop of the belt(s) off. Its alot easier that way then doing it with the pump off the car.
Glowsock
Jul 24, 2025 03:15 PM
evilstuie
Jan 9, 2020 08:29 PM
justin57
Aug 20, 2015 07:05 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
