TPI runners
Old Oct 21, 2000 | 10:30 AM
e-man's Avatar
Car: 89 formula
Engine: 383
TPI runners
Everyone says the SLP runners are crap if so then why does azriona speed and marine sell accel's that are ported semi siamese just like the SLP's and they say the semi siamese make more HP & TQ than there long tube runners.The SLP's port dia. is just a little smaller than the accel's.SLP's 1.600"-accel's 1.615" so I can't see them killing TQ like everybody says.What do you guys think.
89 350 TPI,edelbrock intake,SLP headers,highflo cats,flomaster cat back,accel 300+ ign,ported plenum and runners,ported maf,auto w/shiftkit,cold air induction,AFPR,Ed wright chip,3.23 posie
[This message has been edited by e-man (edited October 21, 2000).]
Old Oct 21, 2000 | 03:09 PM
Vader's Avatar
E,
The physics of the situation dictate that shortening the runner effective length does not necessarily cause a loss of torque, but will move it into a higher RPM range. Some of this can be compensated for through cam profile and the resultant overlap and valve timing.
If you have a lower rear gear ratio without a higher stall speed converter or a manual transmission.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 21, 2000 | 07:41 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I LOVE my SLP runners
I felt no loss of low end torque when I installed them on my L98. Just breathes(sp) better on the top end.
Now I thnk they really help with my ZZ4 with Edlebrock intake.
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
[This message has been edited by Rob P (edited October 21, 2000).]
Old Oct 21, 2000 | 08:30 PM
Yelofvr's Avatar
I just received my SLP's and they look pretty good. I did need to open them up alittle to match the gasket opening correctly. I am deepening the siamezed part a little and widening the opening also to more match the AZS&M runners. They were on sale for $199 and even with $220 in extrude honing, they will be less than the AZS&M runners. Mine did need some work to measure a true 1.60" diameter throughout. I used a carbide cutter followed by abrasive rolls to smooth the finish. I think the work I did will make a difference when I compare the one I finished to the other one which has not been touched yet. If I get them flow tested on my AFR ported base, I will post the results.
Dave Zelinka
Old Oct 23, 2000 | 08:17 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
You need to look at my website.
http://www.isthq.com/~dan/efi.html
Bill Davis is running this system, and even with two bad injectors, he came within .010 seconds of his best-ever E/T. His 60-foot times dropped to 2.08 seconds, so it didn't kill his low-end torque. The people who hate the SLP runners are, I think, forgetting to modify their plenum to match the runner contours. It's important. You have to gasket match these runners to your plenum or else you'll end up with turbulence at the runner opening, which disrupts air flow.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
tazs2000
Jul 15, 2017 08:44 AM
stalkier
Dec 6, 2015 11:25 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
mdtoren
Aug 23, 2015 12:52 PM
Sanjay
Aug 12, 2015 03:41 PM
