2 tenths in the 60 nets 1 tenth in 1/4 ?
Old Oct 22, 2000 | 05:36 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Put the new BFG DR's on, 225-50 15 with small
diameter so as not to ruin my gear ratio. They hooked good cutting my 60 from 2.27
(14.52 @ 96.24) to 2.0x for three runs;
14.44 @ 93.5, 14.63 @ 92.77, and 14.76 @ 94.06. I thought better short times were supposed to result in much better 1/4's ?
Car was not changed at all from the 14.52 run in Aug to these runs. I must have put a whole 80-90 miles on the car between the two times at the track so car variables are small and the car did run good. Only thing
I can think of is the drag difference in the rear tires with the street tires run at 35
psi and the DR's at 23. Also my friends LS1
2000 Corvette ran for the first time and had
3 runs with 100.xx mph for top speed which seems rather low. Maybe weather conditions
(pressure and humidity). This Sat was unseasonably warm in the northeast.
Tom K.
84 z-28 M5 305 HO
pulleys,coil,3:73(stock)
Jet StageII, fan switch
14.55 @ 95.02 2.15 60ft
Old Oct 23, 2000 | 09:07 AM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
I guess I'll ask again on the racing board...
Tom K.
84 z-28 M5 305 HO
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
tricky1
Aug 23, 2015 01:17 PM
