Compcam or LT1
Old Aug 1, 2003 | 02:15 PM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Compcam or LT1
Hi!
My car are real weak before 3000rpm but runs quite good up to 5500 byt maybee I chould go down a little to the LT1 cam or what do you gyes think of this.
Maybee a 670 tb will do my cam justice,please feel free to comments this.
Thanks!!
Old Aug 2, 2003 | 09:05 PM
Vader's Avatar
With the cam profile you have installed, a 305 may not have enough displacement to make low RPM power. If you want more power at lower RPMs, you might want to change to a shorter duration cam. That will help with lower RPM power, but probably cause a loss of upper RPM power.
The cam profile you have listed isn't a complete mismatch, but may be just a bit large. If you have an automatic transmission, another option to improve acceleration would be to install a torque converter with a higher stall RPM.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
