Throttle Response( TPS maybe?)
Old Oct 23, 2000 | 12:22 PM
Beefy89's Avatar
I just got my car running after rebuilding the engine,and it seems to have lost a little throttle response.Maybe it's just me but when you tap the gas pedal theres a little hesitation before the rpm's come up.Could this be the TPS is out of adjustment,or maybe a vaccum leak?When I put the engine back together,I noticed a spot on the back of the EGR selenoid next to the connecter,that looks like a vaccum line plugs into it.Anyone know if there is supposed to be a vaccum line connected there?I set the base timing at 6*btdc.89 l98,96LT1 cam,1.6 roller tips,Speed Pro 9:75 to 1 pistons,SLP headers without AIR,ported and polished L98 heads,intake,runners and plenum,Cloyes double true roller chain.
We need Perry Mason
Old Oct 23, 2000 | 02:25 PM
rondubbs's Avatar
did you reset your tps and iac?
Old Oct 23, 2000 | 02:55 PM
Beefy89's Avatar
No.When I took the engine apart,I left the throttle body on the plenum in hope that the tps,and iac would be set close enough for the car to run.
We need Perry Mason
92firebirdguy
Sep 1, 2016 07:53 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
Randomtask2
Sep 7, 2015 05:06 PM
rsrookie
Sep 5, 2015 07:08 PM
