help me choose my next mods...
Old Oct 21, 2000 | 06:17 PM
kream-'s Avatar
setup:
1988 iroc, zz4 crate motor, edelbrock TES headers and everything else is bone stock.
2.77 posi 9 bolt, and dying 700r4 (have a rebuilt one in my garage... just being lazy)
i have around 500 to 600 to spend..
obviously i need an AFPR so i guess that drops my spending money down to around $400.
now should i go for dynomax catback and SLP runners with the extra $?
so far that seems like my plans.. afpr, slp runners, and dynomax catback.
if you can think of anything that would give a better bang for the buck lemme know!
thanks for the help
17 from Wichita, KS (previously newbieZ28)
1988 Iroc-Z ZZ4 tpi, ttops, 50k miles on chassis (edelbrock tes, stock tpi) free mods etc coming soon after first 1/4 times!
1985 Z28 LB9 option [STOLEN!] Click here to see
http://thirdgen.bawx.org
K.I.S.S - Keep It Simple, Stupid.
Old Oct 21, 2000 | 06:19 PM
kream-'s Avatar
btw.. i would port the plenum and probably see if i couldnt get a little porting done to the stock intake..
Old Oct 21, 2000 | 08:38 PM
CanadianBeast's Avatar
You could build an afpr for about two bucks, ask vader he has an article on how to do it.
Old Oct 22, 2000 | 10:54 AM
JeffP's Avatar
The best bang for the buck is going to be deeper gears. I suggest buying a complete 3.2x or 3.4x 9 or 10 bolt rear end, used. This should certainly be within your budget.
And instead of the dynomax catback, why not get a cutout, and place it on the exhaust pipe right before the pipe bends to go over the rear axle? Dont put it right after the cat, put it right before the bend over the rear axle. Hope this helped.
Old Oct 22, 2000 | 10:59 AM
Jester's Avatar
Why would you want to put a cutout that far back? Thats gonna only cut out less than 20% or so of the restriction.....put it as far forward as you can.
Old Oct 22, 2000 | 11:04 PM
kream-'s Avatar
i already have a cutout but i dont have anyone to weld it on 'BEFORE' the cat for me..
also i was trying to wait on the gears because traction is already terrible as it is..
Old Oct 23, 2000 | 03:44 PM
JeffP's Avatar
Putting the exhaust too far forward will decrease the backpressure, and your car will run like a turd. Dont believe me? Unbolt your exhaust at the cat, and take it for a WOT run. The car now has lost tons of bottom end torque, and overall runs like crap. Placing it before the bend will have about as much restriction as a nice catback exhaust, but will be much cheaper.
How do I know this? I dropped my exhaust at the cat on my 89, and the car lost tons of bottom end. Wouldn't even turn the tires over. I now understand how important backpressure really is.
If you can hook, I would conservatively say you will drop .3 to .4 tenths with the rear swap. Pick up some ET Streets, or some Nittos
bjpotter
Oct 4, 2015 07:48 PM
Vincent135
Sep 28, 2015 10:50 PM
Victor6
Aug 30, 2015 02:09 AM
ElPaleterro85
Aug 13, 2015 03:49 PM
Scott 88 GTA
Aftermarket Product Review
Oct 30, 2000 12:34 PM
