Hesitation
Old Aug 2, 2003 | 10:11 PM
STEEL_DRAGON's Avatar
Hesitation
DRAGON
EVERY TIME I SITTING AT A LIGHT OR AT IDLE AND I GUN IT OR FLOOR IT THERES A ..SORT OF DELAY OR HESITATION TO GO COULD THIS BE A FUEL OR THROTTLE PROBLEM ?
P.S ITS A 92 Z WITH 350 TPI DUAL CATS AND FLOMASTER EXHAUST HEADMAN HEADERS AND 4-SPEED AUTO.
Old Aug 2, 2003 | 10:45 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
need more info on it.. what type of induction are you running tpi, tbi, carb? kinda hard to tell with that combo you have since it didnt come stock in any 3rd gen.. im guessin you mean a t-5? anyhoo give us as much info as possible and im sure someone will point ya in the right direction
Old Aug 2, 2003 | 11:10 PM
89RsPower!'s Avatar
k so its a tpi car with a 700r4.. personally i'm not too familiar with tpi as i have never owned or worked on a car with it but many people on this board are so maybe someone else can help point ya in the right direction.. if the cars in good tune(good plugs, wires, etc) i would think it is an iac/tps problem.. pull the iac motor, clean the passage/motor itself, reset minimal air flow and tps and go from there.. maybe someone else can give ya some better advice.. for more info on settin the tps and stuff do a search.. i think the setting is .54 at closed throttle but i could be wrong..
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
