perimeter bolt heads but wanna keep center bolt vavle covers and wire looms
Old Oct 23, 2000 | 04:19 PM
bad camaro RS's Avatar
i saw somewhere that theres a kit to that i can use on perimeter bolt heads so i can use centerbolt valve covers i wanna keep my valve covers and wire looms you know who sells this kit
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
2000 tci stall
700R4 with B&M shift kit
Old Oct 23, 2000 | 11:21 PM
Vader's Avatar
RS,
I know that GMPP offers an adapter that allows the use of perimeter covers on center-bolt heads, but not the other way around. You might want to check Mr. Gasket or another such supplier. If you have a mill and a little spare time, you could hew your own out of some flat stock, then hold them down with flat heads and weld coupling nuts to the area that the center-bolts would thread into. The space taken under the cover may create problems with rocker and valve clearance, however.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
355tpipickup
Aug 25, 2015 12:54 AM
penguinpanda0
Aug 15, 2015 06:45 PM
