Performer or Performer RPM
Old Oct 23, 2000 | 07:51 AM
BadAssBerlinetta's Avatar
Why does it seem like most of you guys are running performer rpm intakes on your setups that are very similar to mine?.....355, XE268 grind cam, 3.42 gears, 9.1 compression, carb...yadda yadda.....very common type setup.....Are you all pushing your stock bottom ends to 6500 rpm's?.....Just wandering, cause I called edelbrock, and they told me that up to 5500, the performer is a better manifold.....only beyond that is it better.....so are you all pushing past 5500?........Just curious,thanks.
Old Oct 23, 2000 | 11:39 AM
Baz89RS's Avatar
I guess most people here with some mods are.. I was turning my motor to 6800 RPM's with the performer RPM's and a stock bottom end. (I did pay for it after a while though)
Old Oct 23, 2000 | 02:37 PM
Anyone else?.......Would love to hear from all the people here using a smililar setup.
Old Oct 23, 2000 | 03:13 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
the hot rod article that I copied to do my engine buildup showed no benefits from the performer that the performer RPM didnt make up for. I spin to 6000. anything more and I get scared
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
Old Oct 24, 2000 | 07:38 AM
Biochem's Avatar
Car: 2002 SOM z28
I spin to 6000+, but not often. The Performer intake can go higher, but I bet the flow is not as good. I needed the EGR stuff...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 9, 2015 10:01 AM
86iroczwv
Sep 3, 2015 06:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
