How to adjust roller rockers
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
Ok, I have a set of 1.6 ratio crane gold race roller rockers. I have my engine pulled apart right now becuase I spun a bearing really bad, but when I get the engine back together I need to know how to adjust the RR's correctly. I had my mech do it for me last time, but I should be able to do it myself, it's just getting the last just right i'm not sure of, and I have heard so many different things on how to do it, and I want to find out exactly the correct way to do and and how to know you got it right. Thanks guys.
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Get the valve your adjusting closed on the base circle of the cam, turn the pushrod between your fingers and tighten the polylock till you just start to fill resistance on the pushrod. This should be zero lash, then tighten 1/2 to 3/4 of a turn more.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
