Is 5 quarts of oil too much for my 3.1 V6?
Old Aug 3, 2003 | 11:05 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Hey guys,
I just gave the car a fresh oil change + filter yesterday. Today when changing oil on a friends car, i figured I might have put too much in the car, i checked the dipstick and it reads just above the crosshatching. I talked to a number of people with 3.1s and they all say 5 quarts, I am using a PF-52 AC Delco filter as well. I hear that too much oil eats away at seals and causes leaks and bad stuff to happen, will this much oil hurt my car?
Old Aug 4, 2003 | 10:51 AM
Is it that hard of a question?
Old Aug 4, 2003 | 11:13 AM
DaGoat's Avatar
4 1/2 is all mine needs.
Old Aug 4, 2003 | 11:29 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
for the v6 and v8's (305 or 350) takes 4.75 qts of oil but just put the 5 qts in and be happy. thats what i do with my car (305) and my brother does to both of him camaro's a 305 and 350
Old Aug 4, 2003 | 01:02 PM
okay that means that it will not cause blue smoke on startup and eat at seals? its just 2 mm above the crosshatching. I dont mean to be a PITA but my engine is in excellent shape and i want to keep it that way.
Old Aug 4, 2003 | 02:32 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
half a quart under/over is not going to hurt your engine... when you get more than that amount that's when you're going to have problems if it's left unattended.
Old Aug 4, 2003 | 02:43 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
and the blue smoke on start up is ur valve seal wearing down and not sealin as good becuz that is a wearable part meaning u have to replace them when they go bad, its just like tires or ur oil. when it starts goin bad u replace it. its just from normal wear and tear on the motor.
jrdturbo
Mar 31, 2016 02:58 PM
NZKnight
Oct 15, 2015 02:47 PM
88CamZ
Oct 8, 2015 10:29 AM
skinny z
Oct 5, 2015 06:23 PM
