Occasional Hard Starts
Old Oct 24, 2000 | 07:24 PM
F15EagleE's Avatar
When I start my car for the day, it starts just fine. If I try to start it after I turne it off for like 5 mins it will give the good old sound of a dead battery. However, 10 mins later, it starts like a champ again. At first I suspected that the starter was suffering from heat soak, but if I turn it off after starting and 5 seconds later start it, it will start fine... but 10 seconds after that, I have to wait for the 15 mins to start again... the odd part is that if I hook up someone to jump me, it works fine....
Glenn
86 Z28
Kat-back exhaust... uhh thats it... (also get an awesome 10.. count 'em 10, mpg)
Old Oct 24, 2000 | 07:47 PM
Vader's Avatar
F15,
If all the electrical connections from the battery are in good condition, I think your original presumtion is probably correct. The starter may be developing a heat-related failure.
The fact that is will start within a few seconds of being shut off is not unusual. The internals get tighter when the oil stops flowing, and the starter actually gets a little warmer in the first few minutes after a shutdown.
You don't come over the fence "hot" then immediately shut down your P&W F-110 fans without a little water spray first, do you? (Cracked turbine blades can wreck you entire day.) The same is true for your piston engine groundcraft, but you probably don't have the luxury of water spray to cool it down before turning it off.
A new starter/solenoid designed for higher starting torque should solve most of your problems.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
eightsixseven
Dec 16, 2024 01:50 PM
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
cstrobel65
Aug 15, 2015 10:19 AM
