need to know what rear end i have
Old Oct 24, 2000 | 08:47 AM
hookin88formula's Avatar
today when i took my car into the muffler shop the mech. put the car on the lift and when it was lifted up u could clearly see "84" in yellow marker on teh rear end. as we looked closer i noticed a tag connected to one of the diff. bolts. now i am thinking this is a tag for a posi rear end. or should i say the tag that tells me to put that special lube it the rear end. anyways i counted the botls and there are 10 of them. assuming that its a 1984 rear end how do i know what gears come in the car and what other if any special oddities the rear end has.. thanks in advance.
1988 firebird ws6 formula350tpi msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter, march underdrive pullies, tpis airfoil cvr high torque starter (love it)
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system
Old Oct 24, 2000 | 09:53 AM
theformula's Avatar
Take off the 10 bolts when the car is jacked up. (it's easy..they're supposed to be a little loose).
Take a look at the differential. Does it have spacers and 2 springs in it? If it does then it's posi...
If you want to find out the gearing..look for two numbers with a colon in between.
Example : 11:41 was on my car
41 divided by 11 is 3.727. Rounded to 3:73!
Just look for any two numbers separated by a colon and divide like I did.
'92 Formula
305 TPI
Mods: SLP catback,SLP air foil,ported plenum,Crane AFPR (49psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch...SLP 1 5/8ths are coming...oh yes
Old Oct 24, 2000 | 10:14 AM
ok thanks formula i will try that anyone else have any input?
Old Oct 24, 2000 | 12:44 PM
82camaro's Avatar
Car: 82 camaro SC
If you don't want to pull the cover off.
Put it in park and raise the car up. Try to spin the wheel. If it spins easy and the other wheel spins the opposite way, you have an open rear end. If it won't spin, you have limited slip.
To check the gear ratio with limited slip:
Put the car in neutral and raise it up. Turn the wheel exactly one turn and count how many times the drive shaft turns. About 3 turns is 3.08. A little less than 3.5 turns is 3.42. Etc.
To check an open rear you can use the above method if you make sure both wheels turn exactly one turn the same direction. Or, you can hold one wheel steady and turn the other 2 turns and count the turns at the driveshaft.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Oct 24, 2000 | 01:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I also believe that I've heard if only one wheel will spin forward, then the driveshaft will spin twice as fast. So you wouldn't really have a 6:1 ratio, it'd be a 3:1.
Pulling the cover's the best way tho, and if you have rear discs, there's a good chance you've got the 3.73's!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 24, 2000 | 08:02 PM
i know for a fact that i do have disk brakes!!! so anymore input is great thanks a bunch
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
