When do I need aftrmarket fasteners (ARP, FelPro etc)
Old Aug 6, 2003 | 02:23 AM
max_est's Avatar
Car: '89 RS
Engine: LS3
Transmission: TR6060
Axle/Gears: 3.42, 10-bolt
In mild engines, you don't need aftermarket fasteners (mains, rods, heads) and in performance engines, they are MUST. Where is the limit? I've heard, that 0-400hp and 0-6000rpm engines don't need aftermarket fasteners. Little over that you need aftermarket bolts and more further, you need studs. What is your practices and opinions?
Are FelPro fasteners as good as ARP ones?
Old Aug 6, 2003 | 05:06 AM
ede's Avatar
ede
i wouldn't put an engine of mine back together without arp rod bolts reguardless of it's intended usage or HP level.
Old Aug 6, 2003 | 05:44 AM
max_est's Avatar
Car: '89 RS
Engine: LS3
I've got ARP rod bolts with new Scat forged rods. Just thinking about mains and heads. I'll use AFR 190 heads and 224/230 hydr roller cam and carburetor with RPM intake. Block is from 1988 trans am. I think, that I should be make appr. 420hp@5500 and I'll won't rev it above 6000rpm.
Bohemian
Aug 15, 2017 05:11 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
