1988 350 idling problem?!?!
Old Aug 6, 2003 | 08:39 PM
hunterthompson's Avatar
Ok, I really need some help here. Car will idle back and fourth from 500 to 700 rpms. Some times when the car is costing at like 15 to 20 mph it wants to stall, but after a few seconds the rpm's will kick back up. I've changed like every sensor IAC,TPS,MAP..ect nothing no chang . No check engine light , no codes. I Would appreciate any help here It's really getting on my nerves. Tahnkx
Old Aug 7, 2003 | 08:25 AM
Merlin's Avatar
Search for vacuum leaks, clean the throttle body, check the TPS voltage, and make sure the fuel pressure remains stable.
Dr. Hunter Thompson?
Old Aug 7, 2003 | 09:58 AM
I did all that and still nothing.
jhawkeye
May 25, 2022 06:33 PM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
