Biggest rear tires for 14" rims
Old Aug 7, 2003 | 08:36 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I did a search, but came up with nothing for 14" rims.
I ahve 14" Centerlines... I love the look and I want to use them for the strip... but I'm affraid as to how big I can go. I don't want to gouge holes in the sidewall from the inner 1/4's!
The rims are 14" x 11 or 12"
thanks!
Old Sep 5, 2003 | 05:30 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
...anyone? Is 14" really that undesireable?
Old Mar 4, 2004 | 10:07 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
lol guess so
Old Mar 4, 2004 | 05:41 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Well 14" rims and tires are kind of old school and obsolete- they still make tires for them due to the fact there are a lot of old musclecars still sporting the original rally rims, but a 245-60-14 is about the biggest commonly availible tire and you won't find that size in anything but a low speed rating- i had that size in a BFG Radial T/A on some 14X7 aluminum turbine style (sort of like Dukes of Hazzard rims only with more spokes) on my S10.
You can get a bias ply Mickey Thompson Indy Profile in an N-50-14 which is 26.6" OD, has a 11.8" trad width and needs a 9 to 12" wide rim to mount on. Summit has them for $149.95 each. It's a reproduction of what I thought was kool in the early 80's, you need to spray paint your break drums and rear axle orange and put in air shocks pumped all the way up to complete the look.
Eric
Old Mar 4, 2004 | 07:03 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Well, I'm just affraid that they will rub the inner 1/4 like the last set did. I don't know how tall/wide I can go; and not have to worry about popping a tire!
Old Mar 5, 2004 | 09:56 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
15 or 16x8's will have a better tire selection and actually fit. If it's for the strip, get proper racing tires mounted on reasonably-sized rims, and you'll be better off traction-wise.
eightsixseven
Dec 16, 2024 01:50 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
1nastygta
Aug 8, 2015 07:38 PM
