Anyone using Water Wetter with the mix of 50/50 water and antifreeze ?
Old Oct 26, 2000 | 01:01 AM
voltran's Avatar
I wanna add water wetter into my raditor. But since the winter is around the corner, I need to keep some antifreeze. Do they work together, or does water wetter work at all ?
Old Oct 26, 2000 | 01:06 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
ive heard water wetter works very well. ive never tried it myself though. i beleive you just add it to your 50/50. good luck
rICK
Rick
90 Camaro RS 305 TBI
350 on the way!!
Old Oct 26, 2000 | 07:32 AM
82camaro's Avatar
Car: 82 camaro SC
The water wetter works great with a 50/50 antifreeze mix. It will work better with straight water, but straight water will cool better than 50/50 antifreeze anyway.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Oct 26, 2000 | 08:20 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Ummm, I thought anti-freeze was also an anti-boil formula, as well... supposed to keep it running cooler than just straight water. What is this water wetter stuff? I read about it somewhere else, but forgot it just as quick...
KAM
Old Oct 26, 2000 | 08:42 AM
merf23's Avatar
Ive used it in many kinds of cars with good results, works great in Dads old flathead caddy. It decreasesm the cohesive properties of the water molecules (something like that, chemistry classes were a long time ago!). Basically it causes the water to "sheet" insead of forming droplets, which increases the surface contact with the engine and radiator therefore increasing the heat transfer. Dont expect this or any other additive to cause a dramitic drop in temp, but they will take the edge off.
Old Oct 26, 2000 | 11:16 AM
Biochem's Avatar
Car: 2002 SOM z28
KAM
Water has the ability to absorb more heat then a 50/50 mix. Antifreeze also changes the freezing/boiling point of pure water too. It also helps with corrosion too.
Water wetter can be bought through Jegs.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
sheachopper
Jul 31, 2019 11:27 AM
MrPackstin
Oct 25, 2017 08:09 PM
HoosierinWA
Oct 7, 2015 10:15 AM
rusty vango
Sep 29, 2015 02:44 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
