L98 Heads Ultimate Performance Setup?
Old Oct 26, 2000 | 12:28 PM
BranT's Avatar
I have a set of L98 heads that I want to set up on my 91 Z28. I want to do the works to these heads. What is the best things to do to them? Do I need to look into 2.02 valves? I want the car to run low levels on the bottle and 12s on the motor. I know there are better heads out there but I have these already. Thanks, Brandon
Old Oct 26, 2000 | 12:39 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
"The Corvette L-98 head lends itself to excellent flow with some intelligent port work. Valve size is limited by the factory seat inserts to 2.00/1.56-inch valves but with the proper port work these heads can generate up to 250 cfm of intake flow at .500-inch valve lift with an excellent E/I above 70 percent." -John Lingenfelter, On Modifying Small-Block Chevy Engines.
-Mark W.
'88 SC Camaro w/ 305 TBI
lt500r55
Sep 1, 2021 01:30 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
