CODES
Old Oct 26, 2000 | 09:29 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
CODES
Is there a section that deals with codes? My car had trouble starting this morning and is storing a code. The engine seems to be running normal, however the check engine light stays on. I need to know how to get and interpret the code.
Regards,
William
Old Oct 26, 2000 | 11:09 AM
rondubbs's Avatar
https://www.thirdgen.org/faq/thirdgen.shtml#misc
Old Oct 26, 2000 | 11:19 AM
wm_sorg's Avatar
Thanks,
I read the article and it mentions two diffrent ECM configurations. I have a 1991. Which pins should I use. I do not want to risk damaging the ECM by connecting the wrong pins.
Cheers,
William
Old Oct 26, 2000 | 03:04 PM
rondubbs's Avatar
i believe its the 2 upper right pins..
someone back e\me up on this.
Old Oct 26, 2000 | 04:13 PM
Blade's Avatar
You're right. It's the two top right pins.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
