cars turnsover at normal speed, still won't start
Old Aug 10, 2003 | 07:34 PM
berklified's Avatar
hey guys,
having some car issues, i have an 87 5.7L that now has a simple 650cfm carb on it. it will turnover at normal speed, but will not start
I DO NOT HAVE SPARK
i replaced a fusable link on one of the three red wires coming from the starter motor, with no luck
the other fusable links read 0.4ohm's so i take it those ones are still fine
now, my question now is what else could be wrong, and if i did not replace the correct fusable link, where are they all FOUND!!!
reason i ask where they are is because i am having some confusion as to where they should be located.
i really need help and fast, these are my daily wheels
-mark-
Old Aug 10, 2003 | 11:59 PM
SlowMaro's Avatar
ok first of all check your wires, plugs, the normal problems, coil might be dea, ...wires might have gotton mixed up. the entire fuseable link distribution block lies right beside the battery against the side of the radiator , in a open ended circular black housing, check all of those by squeezing the wires , inch by inch. if it squeezes in easily, its fried.
Brcharrelson
Aug 26, 2015 07:47 PM
B_Dubya
Aug 26, 2015 05:09 PM
justin57
Aug 20, 2015 07:05 PM
mustangman65_79
Aug 8, 2015 12:07 PM
