Rocker clearance w/ Pro topline heads....
Old Aug 11, 2003 | 12:29 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I'm having interferance problems w/ my LT4 rockers and the bigger springs. Will I have the same problem w/ the Pro magnum rockers? The rocker arm body is hitting the retainer.
Thanks.
Old Aug 11, 2003 | 12:36 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
GM Lt4 rockers have limited lift travel clearance. They are also made for the small diameter valve springs.
You may have a problem with rocker geometry. Different length pushrods may be nessessary.
Comps Pro magnum rocker should clear the larger retainer better.
Old Aug 11, 2003 | 01:40 PM
rjmcgee's Avatar
I am running a set of Comp roller tips and they cleared fine. You will probably want to purchase an ajustable pushrod to take the guess work out of the geometry.
3.8TransAM
Sep 17, 2015 02:16 PM
alpine247
Sep 16, 2015 05:25 PM
gixxer92
Sep 1, 2015 04:32 PM
LT1Formula
Aug 20, 2015 09:36 PM
