Iron Duke spitting out code 42......
Old Aug 11, 2003 | 10:59 PM
84 Challenge's Avatar
Read the thread below too! Not sure what to check for a 42. Manual says something about electronic spark control. I do know the plug gaps are wayyyyyy off. Could that cause a 42? What else can I check?
https://www.thirdgen.org/techbb2/sho...hreadid=195916
Thanks,
Brandon
BTW, car hasn't been started since Feb and is probably lacking some maint.
Old Aug 11, 2003 | 11:45 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Is your base timing set properly? Get a timing light and check it out. If not you may have a bad ignition module. If the timing is too far off, it will set code 42. Hope that helps you some.
Old Aug 12, 2003 | 12:14 AM
To be honest with you, the timing has never been checked. How can you tell if the ignition module is bad?
Brandon
Old Aug 12, 2003 | 12:20 AM
Ok there's a couple ways of doing it, but probably the easiest way for you is take it off and take it to auto zone and let them test it for you. Be sure to get some dielectric grease and put it on the base of the module before you reinstall it. Oh, it may be a good idea to take the module in when it's hot, sometimes they suffer from "heat soak", meaning they don't work properly when they are hot, but work great when they are cool. Hope that helps.
Old Aug 12, 2003 | 12:42 PM
This morning the SES light stayed off, but the engine continued to spit, sputtered, smoking and eventually died a few times. For a good tune up: spark plugs, wires, rotor, dist cap, ignition module....what else?
Brandon
Old Aug 12, 2003 | 10:00 PM
Damon's Avatar
Challenge- there are few people in the workd I trust more when it comes to the computer controlled TBI iron duke than my brother. He's worked on a LOT of these things. He just gobbles up computer problems like this. Basically, he just lives and breathes factory diagnostic trees. If you get real stuck, shoot me an email and I'll plug you into him.
Probably you'll find it's a bad module, ESC module or the ECM itself is bad, but I don't want to suggest any course of action here. THis is a problem that must be DIAGNOSED, not have parts thrown at it. You could do so for weeks and maybe never get it.
Old Aug 12, 2003 | 10:14 PM
Originally posted by 84 Challenge
...... For a good tune up: spark plugs, wires, rotor, dist cap, ignition module....what else?
Brandon
Change your fuel filter as well, along with your air cleaner, PCV valve, and breather filter if applicable. Damon's right, the problem needs diagnosed, and personally I think a good place to start is with a timing light and getting that ignition module checked. Good luck with it.
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
mfp189
Sep 27, 2015 09:25 AM
