door locks
Old Aug 11, 2003 | 11:00 PM
Camaro305to350's Avatar
door locks
I've got power locks and trunk release on my 84z. But the trrunk release doesn't work and my driver side door lock wont lock using the power lock button. Passenger works fine so I dont think the problem is a fuse, any ideas will help.
Old Aug 11, 2003 | 11:42 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
I really don't think it's a fuse. I would say your lock popper in your driver door needs lubed. Try that out and see what happens. As for your trunk, that may be a fuse, do you notice anythng else not working that should be? You may have a bad connection at the switch or at the latch, so check those out as well.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
my86bird
Oct 23, 2015 12:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
SG91camaro
Sep 5, 2015 10:27 PM
