Problems starting
Old Aug 12, 2003 | 01:54 PM
MasterEvilAce's Avatar
Problems starting
'87 IROC, 350 TPI
While holding the key to start it, and even when giving it gas, the car takes approx. 3-5 seconds to start.
If I turn it off, and back on, again, it fires right up.
I know the sparkplugs are old, and I changed 2 a couple months ago (engine was flooded) and the 2 old ones BROKE in half, while taking them out.
But I believe it still started right up, then.
I put some injector cleaner in, but I doubt it's gotten through the engine, yet.
Not sure what it could be.. what does it sound like? Starter? spark plugs? Injectors, possibly?
Old Aug 12, 2003 | 04:26 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
When the key is put in the ignition and turned as described, what exactly happens during those 3-5 secs?
Does it crank slowly?
Does it do nothing and then suddenly crank?
Elaborate on your previous description some...
Old Aug 12, 2003 | 06:08 PM
it cranks for a few seconds, and then finally starts up
i'm not that experienced with cars, so I can't give technical terms
Old Aug 12, 2003 | 06:34 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
If it cranks, I would guess, a weak battery or a dying starter...
You will need to do more investigation before condemning either...
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
