Rocker Stud Removal
Old Oct 15, 2000 | 08:02 PM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
Rocker Stud Removal
I have a set of heads with the pressed in rocker studs and I wanted to get the Tavia or Proform tool to remove the studs so that I could put screw in studs. I was wondering if anybody had any experience with these tools and if there was alot of effort into the project.
Old Oct 15, 2000 | 11:49 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I'm not familliar with the tool you are talking about but why don't you just have a machine shop pull them for you??
The heads have to go to the shop anyway to get the stud bosses machined off for screw in studs.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Oct 30, 2000 | 07:26 PM
ede's Avatar
ede
i pull my own studs. i just stack up some washers and tighten a nut on them, it pulls the stud out. you have to stop and add more washers after a while. i mill the stud boss myself and tap it for the screw in studs.
-=ICON MOTORSPORTS=-
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
TheExaminer
Sep 6, 2015 11:40 PM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
