bronze dist gear? or factory GM gear?
Old Aug 14, 2003 | 07:55 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Looks like I need to replace the dist gear on my GM hei dist. The cam in the motor is the factory L98.
My question is, would a bronze gear be ok with this cam, or should I get a factory Gm gear?
Thanks guys.
And yes, for the record, this is about my other post "worn dist Gear / carb backfireing". Its on this same board if you are interesed in checking it out.
Old Aug 14, 2003 | 08:54 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
just get the stock replacement. The bronze gear is mainly for use with the aftermarket billet steel cams.
Old Aug 15, 2003 | 09:05 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
what diameter shaft is the stock GM dist? is it .500 or .490?
junkcltr
Aug 2, 2019 11:12 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
Orr89RocZ
Oct 7, 2015 12:47 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
