Question??
Old Oct 25, 2000 | 07:49 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Question??
If my belt starting to slip, what would I notice??
First, when my car is at idle, and the heater is on, it blows cold air. When I am around 1500 to 2000 rpm, the heater will blow hot air??
Second, when I drive and keep the car at a constant speed, I notice a slight jerking sensation (well, I can feel it). When I accelerate, its a little worse, the sensation gets a little stronger. Plus it just doesnt seem to pull as hard as it should. I have a TBI 305, and I personally think it should be a bit faster, I can barely light the tires up when I mash on the gas in 1st gear. (Maybe my TB needs a rebuild?????)
I was just curious if any of these problems could be related to a belt slippig??
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old Oct 25, 2000 | 08:32 AM
merf23's Avatar
sounds like a vacuum leak. The heater controls are vacuum operated and will not work right with inadequate vacuum. There is a $3 check valve on the firewall that goes bad sometimes. Does the heater go cold when you are driveing up a long hill or at WOT?
Old Oct 25, 2000 | 09:10 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
I havent noticed on a hill, Ill check next time. What is "WOT" I have seen the lingo used in other post, but couldn't figure out what it meant.
Do you have a diagram or know where I can get one for the vacuum system in my car. I would like to replace all the lines, and check all the components for leaks and failures.
Godti
'89 Trans Am (Red)
305 TBI 5spd
[This message has been edited by Godti (edited October 25, 2000).]
Old Oct 26, 2000 | 12:02 PM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Could you give me some what of an idea of where this check valve is??
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old Oct 31, 2000 | 12:46 PM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Can anyone give me any input on this at all??
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old Oct 31, 2000 | 01:10 PM
Josh 91RS's Avatar
WOT means wide open throttle.
Old Oct 31, 2000 | 02:16 PM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Thanks Josh, I am now a little more familiar with some of the lingo
Still, can anyone help me with my problem??
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
