Popping Afterburn
Old Aug 16, 2003 | 09:47 PM
85Rock's Avatar
Car: 1985 IROC
Popping Afterburn
Hello out there!
I have to tell everybody that I had a hot start problem and it indeed was the fuel injectors. It was hard to sart when warm and when it did start it had a heavy smell of raw fuel. Five of the injectors were leaking( I did the papper trick to test) . thanks for the help from everybodys old posts...
I do have a new ? is it normal to get any popping Or afterburn when freereving a hot engine.. I had just taken it out for a test drive after the injector swap and She ran great and no popping on hard aceleration or deceleration. But when I just gave it a good shot of gas in park as it was idling down I got one or two pops. Is this normal or anything to be alarmed about. I was very careful with the vacum lines and the injectors seating so I don't think that it's a vacum leak. Any suggestions? Thank you in advance
Kristian
Old Aug 16, 2003 | 10:04 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
exhaust leaks around the exhaust manifolds can do that.
Old Aug 17, 2003 | 09:18 PM
ChevTech84's Avatar
Exhaust poping out of the tail pipe is a dead give away for an exhaust valve problem, drop the y pipe to determine which bank the problem resides in. This will also tell you if you have an exhaust restriction that may be causing this problem.
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
RS Reaper
Sep 27, 2015 07:04 PM
Lmancha96
Sep 25, 2015 08:11 PM
