350 intake on 305???
Old Aug 17, 2003 | 04:02 PM
Tbird's Avatar
I am wondeirng if I can use a intake off of a 350 on a tbi 305 I am wanting to convert to carb...
Old Aug 17, 2003 | 04:12 PM
ede's Avatar
ede
there are 2 bolt patterns for SBC intakes, the original design with all the bolt holes at the same angle and the newer design with the center 2 holes closer to vertical and the others in the original position.
Old Aug 17, 2003 | 11:44 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
What ede is saying is yes you can... if the block and intake are similar in the years. Even if they aren't, you can still make it work by drilling the intake holes to accomodate the different bolt angle. To sum it up, yes a 350 intake will work on a 305. What year engine and what year intake are you planning on using? if the block is older than '87, it will have the different angle than the '87 and up style heads.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
