What does porting your comb. chambers accomplish?
Old Nov 1, 2000 | 04:20 PM
Justy's Avatar
Does it help the air/fuel mixture burn faster? I understand you want to do the intake and exhaust ports for better flow, but don't see flow being an issue in the comb. chamber. Just curious, thanks. Justy 84Z
Old Nov 1, 2000 | 04:46 PM
ede's Avatar
ede
it would open up the area around the valve, next to the side of the chamber. part of the valve basically has no clearance around it for gas flow, either in or out. plus a shinny chamber is suspose to promote flame travel and stop carbon build up. i'm sure lot of people know way more than me about this.
-=ICON MOTORSPORTS=-
Old Nov 1, 2000 | 07:50 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Well, ede pretty much said it all. I think the word you're looking for is POLISHING the chamber, because if you Port the chamber, that means you want to decrease the CR (sometimes needed). Yes, you also want to relieve the shrouding of the valves, but this, IMHO, is not considered porting. Polishing the chamber also reduces any hot spots that can promote denotation.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Old Nov 1, 2000 | 07:57 PM
Jester's Avatar
Porting the chamber really isn't what youre after....you port the ports on the head (get it? ) the main reason to polish them being to fight detonation by smoothing over hot spots, and making the surface harder for carbon to stick to.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
