hard to start when cold
Old Aug 20, 2003 | 02:11 AM
PILU's Avatar
Car: Firebird 89' and Formula 87
Engine: 2.8 l and 350 v8
Transmission: 2.8 Manual 5 speed and 5.7 manual 5 speed
I own a 89' v6 firebird, and it gets very hard to start when it is cold, I have to try like 4 times before it starts.
Any ideas:hail: :hail: :hail: :hail:
Old Aug 20, 2003 | 10:34 AM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
Thats a TBi right?
Old Aug 20, 2003 | 03:22 PM
PILU's Avatar
TBi?, I dont really know, it is MPFI
Old Aug 20, 2003 | 05:53 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
my v6 had a problem like that,i replaced,cap,rotor,plugs,wires,coil,ignition control module n nothing helped,then i got down in the dist. and changed the pickup coil and it was gone.
Old Aug 21, 2003 | 05:43 AM
EYEROCK89's Avatar
Car: 1989 IROC
Pick up coil is a bad place to start. Seems like alot of the late 80's cars are having that problem right now. My pick-up coil went out a few months ago. Have you check the obvious stuff like fuel pressure and the air filter?
Old Aug 21, 2003 | 08:24 PM
PILU's Avatar
yep, My fuel pressure its ok, and I hane a racing air filter so I dont thinks thas the problem, and also my dist. coil is new I got like 2 monts ago.
I'm thinking in changing the fuel pump relay to see what happens.
Old Aug 21, 2003 | 10:00 PM
EYEROCK89's Avatar
Car: 1989 IROC
On my last poast, I meant to say that the pick-up cool was NOT a bad place to start...Anyway, I'm not sure what the problem is then. Best of luck. If the relay takes ca re of it, let us know so we can help the next person that has this problem.
Old Aug 21, 2003 | 10:07 PM
PILU's Avatar
sure, I will.
thank you for your help, If i fixe it I let you guys know what was the problem.
Old Aug 21, 2003 | 10:16 PM
Transmission: t-5
which coil did you replace,the little white one inside the distributor or the big ignition coil?
Old Aug 21, 2003 | 10:24 PM
PILU's Avatar
The little one inside the dist. , the one with two connections I think.
Old Aug 21, 2003 | 10:32 PM
Transmission: t-5
well then u got the ahrd part out of the way. if u got fuel pressure u shuld be fine,when the car doesnt start,pull a plug n wire,see if u get spark,if not check to see if ur coil gets spark. try taking ur ignition control module n having it tested also. they do it free at vato zone
Old Aug 21, 2003 | 10:38 PM
PILU's Avatar
where's the ignition control module lacated?
Old Aug 21, 2003 | 10:43 PM
Transmission: t-5
u see how the cap has the slot where the two connectors come out,that little thing is the ignition control module,its around 30 bux for a new one,i replaced it n it hlped just with driveability all around,but it may be your problem. u pup off the cap n rotor,its what the pickup coil hooks into also.
Old Aug 21, 2003 | 11:15 PM
PILU's Avatar
ok I'll try that in the morning, so I cant test it in the auto zone right? for free so I'll go tomorrow and test it, maybe that's the problem. I let you know, the problem is that I have to test my car when the weather is really cold, and where I live this only happens really early in the morning. lol
thanks.
Old Aug 22, 2003 | 09:26 AM
Transmission: t-5
it may be, sometimes they test ok though. my problem was the exact same as yours,but the pickup coil would loose the connection to the control module when it was cold cause the metal wasnt warm enough to have expanded,so it wouldnt contact the pins on the ICM. it sucked,i hunted that problem for over two years,lol.
Old Aug 22, 2003 | 09:57 AM
EYEROCK89's Avatar
Car: 1989 IROC
Yeah, make sure you do use all the dailectric gel they give you for the module if you do replace it. That stuff makes a huge difference with heat build up and breakdown.
Old Aug 24, 2003 | 07:05 PM
PILU's Avatar
yeah, I remenber the gel when I changed the part, maybe I didn't use the gel in the correct way, do you guys know if I can buy more of tha gel??
Old Aug 25, 2003 | 05:57 AM
EYEROCK89's Avatar
Car: 1989 IROC
I think you probably can. It may be called something else though. Go to any auto parts store and trell them what you need
Old Aug 25, 2003 | 06:45 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Sounds like you're talking about dielectric grease.
Old Aug 25, 2003 | 07:15 AM
EYEROCK89's Avatar
Car: 1989 IROC
Exactly.
Old Aug 26, 2003 | 12:35 AM
PILU's Avatar
Dielectric grease, allright Ill' try to get it.
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
apie2546
Aug 10, 2015 05:43 PM
drathaar907
Aug 6, 2015 04:20 PM
