help please!!!
Old Aug 20, 2003 | 03:06 AM
PILU's Avatar
Car: Firebird 89' and Formula 87
Engine: 2.8 l and 350 v8
Transmission: 2.8 Manual 5 speed and 5.7 manual 5 speed
help please!!!
Can any one tell me how to find the fuel pump relay in my 89' v6 firebird. I wolud apreciate.
thanks :hail: :hail:
Old Aug 20, 2003 | 05:44 AM
ede's Avatar
ede
look on the fire wall, look in a manual for a "map" of relay locations. good chance if you do a search you'll find a thread with a pic in it of the relay.
Old Aug 20, 2003 | 08:56 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
relay
autozone.com has a component locator search, but my 88 IROC-Z( same as 89) relays are located on the firewall above where the wiring harness bulkhead connector enters the firewall. To Engage the Fuel Pump - Connect a fused (+12volts) lead to the ALDL Connector Terminal (G), and have someone identifiy which relay on the firewall is energized.
Old Aug 20, 2003 | 03:27 PM
PILU's Avatar
I found it thanks for thr help.
thanks
