Anyone using a S-10 manual steering rack on thier F-Body?
Old Aug 22, 2003 | 09:26 PM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
If so is it as quick of a ratio as the stock power steering setup for an IROC?
Do you have a part number for the steering box?
Tony
Old Aug 22, 2003 | 10:38 PM
pheonix305's Avatar
Car: 1986 Trans Am
Engine: built 305
Transmission: 700r-4 shift kit
i really dought that a truck steering box would have less turns lock to lock than an iroc. but you could always find one and turn the wheel and see how many turns is takes.
Old Aug 22, 2003 | 11:50 PM
gixxer92's Avatar
Engine: 7.0L, 6.2L
It's a question that someone may have an answer to.
Thanks for the opinion I didn't ask for, though.
Old Aug 23, 2003 | 12:07 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
this is a quote from someone on another board that answers your question....
"Yes - It is a lot more turns. Internally the S10 box is 7 turns lock to lock. However, you hit the bump-stops before that. It's approximately 5 turns lock to lock. My Subaru feels like a performance upgrade compared to the IROC - lol.
I don't advise anyone to do this 'mod' unless they either have to or unless your car is mostly a straight-line car. I intend to eventually replace this temporary fix with a power rack and pinion setup having the pump installed on the passenger's side."
Old Aug 23, 2003 | 12:40 PM
gixxer92's Avatar
Engine: 7.0L, 6.2L
Thats what I needed to know, it looks like I'm going to have to spend the 600 for the manual steering setup I need. Thanks for the info.
Tony
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
