FYI w/ AFR heads and SLP Headers
Old Aug 23, 2003 | 07:28 PM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
INFO for anyone doing this stock heads for AFR swap.
You will have to dent both, the #3 and #6 header tubes to get the standard length spark plugs on cylinders #4 and #8 to clear on angle plug AFR's.
Accel doesn't offer 14mm x 3/4 depth, w/ gasket/washer, header sparkplugs for this application.
Oh and with my passenger side, I will have to pull the header off to get the plug out after it's in and you also have to use the thermal plug wire protectors.
I'm starting to hate my car and my back hurts... (poor me)
Old Aug 23, 2003 | 08:09 PM
CDN_87IROC's Avatar
Interesting ... What AFR heads do you have?
Old Aug 23, 2003 | 09:14 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Now which AFR angle plug heads did you get? Their standard angle plug or did you order the L98 angle plug version?
Old Aug 23, 2003 | 11:41 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Damn, glad I have the straight plugs.
Old Aug 24, 2003 | 01:01 AM
gixxer92's Avatar
Engine: 7.0L, 6.2L
Not sure, I've never seen the L98 Angle plugs to know. These go in at an angle and the outside ceramic piece points downward while angling in.
I wish I had straight plugs.
Old Aug 24, 2003 | 04:17 AM
EvilCartman's Avatar
Car: '82 Z28
From what the sales guy said on the phone when I ordered my AFR 195 heads... If you run a straight plug head you're limited to using the 1" 5/8 headers. I got the straight plug version and probably can always come up with something in the future if I decide to go bigger.
formula_novice
Sep 5, 2015 03:58 AM
Talon77
May 19, 2004 12:00 PM
NufNuffZ28
Oct 19, 2003 02:40 AM
