Tach on drugs, help needed
Old Nov 4, 2000 | 01:57 PM
UVA3rdGen's Avatar
My car idles as smooth as ever and every once and awhile the tach will get a mind of its own and jump from 500 to redline to 2000 and haphazordly jump around for an totally none consitant amount of time. Seems to make it better when I disconect the batery and tach wire and reconnect it with the car off. The car never did it until the last time i took the intake manifold off and "though" I set the timming back right. Any ideas?
Old Nov 4, 2000 | 01:58 PM
UVA3rdGen's Avatar
oh ya, might help if I tell ya the car, here is the signature.
She is not the fastest thing in a straight line but she sure will stick in the turns.
Hawian Orchid X-SCCA showroom stock racer 1LE 92 Z-28
-suspension parts include koni reds, eibach racing springs, weight-jacks, relocated control arms, and the list goes on for suspension; Port & polished TPI system sitting on top a fully blueprinted, balanced and matched race built 305; centerforce II clutch; custom 3.4 auburn rear, custom dual cat exhuast with hooker aerochamber muffler; 1LE fuel pump and gas tank; SS track baer braking system; griffin aluminum radiator; 6 point bolted roll cage with 5 point harnesses; pioneer speaker system; sparco seats, just about as light as you can get a weekly driven 3rdgen.
Old Nov 4, 2000 | 06:41 PM
Vader's Avatar
UVA,
Check the routing of the ignition primary wiring to make sure it is not in close proximity to the coil wire or plug wires. There was a TSB from GM regarding erratic tach readings, and that was one of their suggestions.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 5, 2000 | 04:50 PM
UVA3rdGen's Avatar
Just curious Vader, is there anything else you do not know?
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
stalkier
Aug 7, 2015 04:49 AM
