Valve Lash
Old Aug 26, 2003 | 02:29 PM
abcx09t's Avatar
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
Valve Lash
OK, 1987 and newer with hydraulic lifters...
When does the valve lash need adjusting...
How do you adjust the valve lash...
Why do hydraulic lifters need valve lash adjusted????
Thanks,
Scott
Old Aug 26, 2003 | 02:33 PM
demonchild's Avatar
they shouldnt ever need to be adjusted because the hydralic lifter keep the lash at zero. if you think you hear a ticking coming from around the vavle covers...it is probably an exhaust leak.
Old Aug 26, 2003 | 05:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They need adjusting when the valve train wears faster than the valve seat, and the lifter no longer has preload, but instead has clearance.
You adjust the lash the same way as any other Chevy small block. Look in Chilton's or Haynes or Motor's or a factory manual or any number of other places for instructions.
See the first paragraph.
Old Aug 26, 2003 | 07:41 PM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
TPI's tick crazy....if you listen to your engine idling you can hear the injector banks batch firing...
At least mine ticks like crazy... and I know I don't have exhaust leaks....
Old Aug 26, 2003 | 07:46 PM
armac's Avatar
Car: 83 ta
if you do have valve noise then you have might have collapased lifters, bent pushrods or a seriously warn cam
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
dimented24x7
Sep 6, 2015 03:51 PM
