Fuel pump relay won't shut off??
Old Aug 27, 2003 | 09:01 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
When I take the key out of the ignition, I can hear the fuel pump stay on for up to 5 minutes!! Does this mean the pump is going dead?? Sould I change the relay?? This is a new one for me, so any advise would help on this.
Old Aug 27, 2003 | 10:25 AM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
Is it only when you shut the car off? What about when you turn the key to acc? Also, any gas smell during this time?
Old Aug 27, 2003 | 10:32 AM
Vader's Avatar
There are two power supplies for the fuel pump. One is through the relay, the other is through the auxilliary oil pressure switch. If either is sticking, the pump will run on after shut down. A few seconds of run-on is normal as oil pressure bleeds down, but that should last no longer than 5-10 seconds.
The easiest way to isolate the cause is to unplug the FP relay while the pump is running. If the pump stops, the relay is either sticking or the ECM or wiring is energizing the relay when it should be off. If the pump still runs after the relay is disconnected, the probable cause is a sticking oil pressure switch.
Old Aug 27, 2003 | 12:38 PM
Car: 91Z
It only happen's when I shut the car off, I don't think I have any gas smell.
Thanks for the tip's vader, i'll try that and see what the outcome is.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
