fuel pump relay(s)
Car: 1990 Camaro Iroc-Z Convertible
Transmission: Automatic
fuel pump relay(s)
Hey, I know the fuel pump relay is next to the power brake booster, but which one is it, or do they both work with the fuel pump? Both are exactly the same relay. Is the fuel pump relay on the right or on the left(when facing them)??
FBod,
The fuel pump relay should have an orange (12VDC+), green/white (relay coil power), black/white (ground) tan/white (power to pump), and red, or blue, or second orange wire wire (to ALDL).
If you find these wires at one relay, it should be the fuel pump relay.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Later,
Vader
"Make Me Bad"
Car: 1998 Camaro Z28
On my 91 RS 305 TBI, the relay closer to the fenderwell (driverside) is for the fan. the relay closer to the passenger side is the fuel pump relay.
HTH!
Matt
HTH!
Matt
