Need help on wich camshaft to buy...
Old Nov 6, 2000 | 12:31 PM
Tx92rs's Avatar
Ive narrowed it down to 2 of them...I think http://www.cranecams.com/master/apps/chevy37.htm
#3 looks like the obvious choice, requireing really no modding
#4 the only think ill need is a afpr, but mine is an auto not 5spd and tbi not tpi, would this cam be to stout?
now here are my q's:
quote:
e For use with either pushrod guideplate or non-guideplate cylinder heads.
do I meet this requirement?
quote:
f Roller-type timing chain and gears
i assume i have this type?
quote:
i 1.5 ratio (not self-aligning). Will not have sufficient clearance in factory cast valve covers
what size rockers do i have? will need taller valve covers?
Are there other cams than i am missing? please recomened some. I really want to get rid of this peanut cam. Some mods that i have done are: headers, 3" exhaust, ads superchip.
Thanks for the help!
Old Nov 8, 2000 | 04:51 AM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
Well i have no idea what kinda engine you have or anything, but generally as a rule, a camshaft upgrade is one of the last mods you do, after head-work/swap, improvments in the intake and exhaust etc
choosing the right camshaft very much depends on the specifics of your engine
theres a great article about camshafts at
http://www.calgarydragracing.ab.ca/pits.html
which should help you understand how they work.
I would suggest, that since your tearing into the motor anyway, budget in a head porting as well to take advantage of the increased flow your cam will be producing.
good luck!
1982 Camaro Z28...$1000
Vortec 350 block rebuilt 20 over.. $900
L31 Vortec heads...$0 xtreme energy comp cam... $200
Edelbrock carb/intake...$500
home made cold air/ram air induction...$0
dynomax headers...$150
flowmaster 3chamber...$250
rebuild diff, 3.73 richmond swap... $900 built 7004r w/ stock converter... $200
Dusting a 2000 GT with my "truck motor"...
PRICELESS
Old Nov 8, 2000 | 10:04 AM
JimBow's Avatar
I would go with Edelbrock, mainly because they have Dyno matched parts. I don't know what year your car is or what type of induction you have (4bbl, TBI, TPI).
I have a good cam it's the Edelbrock 3700. It's good for low end tourqe,and that's what you want. It's smog legal too. If you have a 4bbl or TBI you can put on a #3704 (87 and up) or a #3701 (pre 87)intake and it's matched to the cam for peak performance.
I have one of these cams brand new in the box if your interested in it give me a E mail. JIM
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
