Lights don't work
Old Aug 29, 2003 | 09:00 PM
smithtc's Avatar
Lights don't work
Headlights, fog lights, dash lights, do not work.
Brake lights, reverse lights, and blinkers DO work.
Besides the switch...what could it be?
What exactly is the "fusible link"? From the starter, where can I find it?
There are 4 red wires that run under my exhaust headers into one of those plastic tubes. There is some melted duct tape, and some exposed wire. Could that be the problem?
I can take the switch out of my other car just to check...but what about the fusible link (?) and the red wires? Possible causes...?
B/w the rain and stupid problems with my car when there isn't rain, I've been pretty grumpy lately when it comes to racing. Haven't had the opportunity
Any help would be appreciated...
Old Aug 30, 2003 | 06:34 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
There should be two small wires that hook to the remote terminal on the starter. One of those is the wire you are looking for. If it becomes disconnected or frayed like yours nothing works. Especially if it is grounding out. Mine did it because I put in a mini starter and the wire was grounding to the frame. Moved the wire and it worked. The other wire just hangs there. Don't know what it goes to. Maybe an old one that was left there when it was replaced, can't remember.
Vintageracer
Jan 10, 2020 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
