Omg.. Fuel Line Burst open! I cant find the right fitting...
Old Aug 30, 2003 | 05:19 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
The rubber piece between the fuel rail's hard line and the hard line on the inside fender (feed line for fuel) of my TPI system has burst open.
It is a dual 16MM Female/Female Hose, and i cant find an adaptor OR new hose ANYWHERE..
I called the dealer they want $30 for a new hose, and im afraid it will just bust like this one. I want to use braided hose.
I have plenty of braided 6AN line, and 6AN fittings.
I need 16MM Female -> 6An fittings. cant find them on jegs or summit...
Any other suggestions?
Old Aug 30, 2003 | 07:56 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
will this work:
P/N EAR-9894DBJ (summit)
Old Aug 30, 2003 | 10:09 PM
OMINOUS_87's Avatar
I blew mine a couple weeks ago as well. I turned over every stone in town trying to find the fittings, they are not available. The hoses are discontinued at the dealer as far as I was told.
I headed to the junkyard and pulled a hose off a yard barge and am running it right now. There are adapters out there for both male and female, dont have the part numbers off hand, gave up on fabbing custom lines when I found the yard part.
In the near future though I will be buying the adapters that fit into the females on the TPI fuel rail and convert to -6AN. Then I will just run SS line to to the frame hard lines and install new -6AN tubing conectors.
Good luck!
Old Aug 30, 2003 | 11:56 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Originally posted by Kingtal0n
will this work:
Yes thats the fitting you need.... With the fittings listed below you'll be able to go from the stock hard fuel lines to the TPI rails using braided line:
EAR-9894DBH - connects to supply hard line on the frame
EAR-9894DBJ - connects to the return hard line on the frame
EAR-991955 - AN fitting for supply line on TPI rail
EAR-991954 - AN fitting for return line on TPI rail
Now buy 6AN hose ends ...you could go with straight (EAR-300106) ones but it might look cleaner if you use angled ones. These parts will let ya do:
hard lines -> DBJ & DBH fittings -> 6an hose ends -> braided lines -> 6an hose ends -> 1955 & 1954 fittings -> TPI fuel rail.
Old Aug 31, 2003 | 11:34 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
https://www.thirdgen.org/techbb2/sho...hreadid=182344
Old Jul 9, 2004 | 09:55 PM
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
Hell yah, I just ordered it up with those part numbers and all the rest of the crap like 135$ worth but I need to drive the beater. Summer is half over. Thanks for the numbers!!!:lala:
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
