87 TPI wiring harness into an 85 TPI
Old Nov 8, 2000 | 01:38 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm planning to swap my POS 85 ECM for an 87 and instead of cutting up my wiring harness, I'd rather just swap that too. Other than the MAF equipment and the dual fans, what else should I be aware of in terms of differences?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 9, 2000 | 06:35 AM
Vader's Avatar
Jim,
I'm not sure of any other differences, but take good notes - I see a Tech Article coming out of this somewhere.
I'm not sure when, but the connector designs changed somewhere between '84 and '86, so you might have an issue with connections at all the devices,
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 9, 2000 | 08:47 AM
Jim85IROC's Avatar
[/quote]I'm not sure when, but the connector designs changed somewhere between '84 and '86, so you might have an issue with connections at all the devices,
[/quote]That would **** me off a great deal if it was necessary for me to replace every single sensor and plug. I gotta think that the TPI sensors were the same throughout the duration. At least that's what I'm hoping.
The IROC Homepage
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
Sanjay
Aug 12, 2015 03:41 PM
